跳转到主内容
Nokia Lumia 920由诺基亚开发并于2012年11月发布,搭载Windows Phone 8操作系统。
56 个问题 查看全部
Nokia Lumia 920 not turning on
i also have the same problem and always do the same thing by press the volume and power on/off and its works usually. but now its not really work. there are no any response when the phones was charging. it looks died. the hard reset also cannot do anything. whats the problem??!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
Connect the phone to a PC (be sure your cable is working).
Try to switch it on. If the PC recognizing your device 90% you have a SW problem. Try to restore the phone:
Windows 8/8.1 Windows 10 Boot Manager Error Solution
If your PC does not respond when you connect the device, then the problem is hardware, broken USB connector, logic board damage...
Regards.
这个答案有帮助吗?
得分 2
1条评论:
@zfix I referenced one of your you tube videos to help someone just now thanks for the video it was great
完成的
添加一条评论
You try reset factory?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
caercspf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 497
