跳转到主内容
The Asus Transformer Pad TF103C is a 10.1 inch Android hybrid tablet released in June 2014. It is specifically for entertainment use with wifi ability.
Why won't tablet screen ROTATE?
My tf103c screen won't rOtate and have:-) No sound can aNyone :-)help me .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
With regards to screen rotate have you checked that the following setting is ticked?
Settings > Screen > Auto Rotate.
Also the screen won't rotate if the keyboard is docked.
With sound, have you tried using headphones to see if there is sound?
Update (04/17/2016)
Hi,
Try the following.
Use the tablet's backup feature to backup your tablet.
Then reset your tablet using the factory data reset feature.
Once your tablet has been reset, see if the touchscreen and the sound work properly.
If so it may be that either a software glitch or a downloaded app was causing the problem.
Restore your tablet with the backup you made, using the tablet's restore feature.
See if the touchscreen and the sound still work.
If so, the reset has fixed whatever glitch was causing the problem
If not, perhaps a downloaded app is causing the problem.
The trick is now to find out which one.
这个答案有帮助吗?
得分 1
2条评论:
The auto rotate is on an I've tried headphone jack still no sound
完成的
I'll give it a try thanks
完成的
添加一条评论
still can't rotate..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ericjnash 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 12,592
