跳转到主内容
加入维修社区 - 创建账户
Is my MacBook's Internal Speaker Blown?
Hi There,
When I play a music or other sound and set the volume more than 3/4 of max volume, I hear disturbing rattle/cracking sound especially when playing music with great bass. Rattling sound most likely come from left side but when I drag left-right balance to full left or full right, Rattling sound gone. Someone can tell me what happen actually with my mac? Is it really blown or this is usual problem?
Thank You
Sincerely,
Athaariq
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
3条评论
Hello Apple 
My name Sajid Ali I am From Islamabad, Pakistan I have 2 issues with my MacBook
Battery Service Recommended battery time is around 1h 3m only
完成的
Yes. I was just listening to music and the speakers started sounding like crap. The music wasent even loud.
完成的
My macbook still makes that sound -Macbook 2014 14 inch
完成的
添加一条评论
9个答案
已选择的解决方案
Try using the balance control in the sound control panel to isolate what speaker is having problems. Don't forget you also have a third speaker! A subwoofer.
It's possible you have something loose which is vibrating. Have you had anything altered in your system? If you did I would review that area.
这个答案有帮助吗?
得分 7
10条评论:
I've already used balance contol. when I drag slider to full-left or full-right, rattling sound gone. Maybe the subwoofer has been blown, or maybe something loose after I bring my mac to the service center. I will find out
完成的
hey i am having the same problem. can you tell me how did you solve it ?
完成的
Did you try the sound balance control? Are you able to isolate out which speaker?
完成的
Hi! I found out my right speaker is busted. How do I fix this?
完成的
显示更多的5条评论
添加一条评论
I have replaced both speakers of my Mac Pro A1398 Mid 2015, on three (3) times. Still it keeps on bursting the edge of the speaker - rattling sound.
I THINK APPLE SPEAKERS ARE DEFECTIVE FROM THE TIME OF MANUFACTURE.
I have ordered another set this time from Ali express. Last replaced in December 2017. Last pair bought from ifixit, it lasted for 6 months - longest period it lasted. Now again rattling.
这个答案有帮助吗?
得分 3
3条评论:
I have the same problem..I have ordered the new speaker (only the left) from Ebay..14 days later the speaker has broken again!
完成的
same here, the right speaker seems to go on the mbp 15' early 2013 retinas, when i ordered a replacement set the ebay seller sent me a defective right speaker as well, i called him out with pictures to get a refund
完成的
Same problem with 2 MacBook Pros (retina) - out of warranty.
Use headphones, bluetooth to Bose or Jawbone speakers or
Airplay to AppleTV, especially for FaceTime/Skype.
完成的
添加一条评论
I use EqMac2 to balance out the noise and make it less noise with bass - it works for me.
这个答案有帮助吗?
得分 1
1条评论:
Thanks. Worked.
完成的
添加一条评论
My Mac book pro retina 2013 have a same problem how to fixed ?
这个答案有帮助吗?
得分 0
1条评论:
Sounds like you need a new speaker or two. Use the balance control to help you isolate out which is bad.
完成的
添加一条评论
i have a same problem does apple fixes for free ? it its been three years that i have this mac, which is already over the warrenty preriod . my one is 15 inch mac book pro retina late 2013.
这个答案有帮助吗?
得分 0
1条评论:
Sorry Apple won't fix it for free. Time to test out which speaker using the slide control and then decide if you want to fix it your self or get someone to do it.
完成的
添加一条评论
I have similar problem. This happened two weeks ago and has gotten worse!
My MacBook pro is model 2017 with the TouchBar.
这个答案有帮助吗?
得分 0
4条评论:
@honeebee - Apple has a warranty repair for blown speakers in both the 13" & 15" 2016/17 systems! Apple will replace the damaged speakers for free. Make your way to an Apple Store or Apple authorized service center.
完成的
Even after the warranty period ?
完成的
have the same problem, I bought my mac on the beginning of 2016. does apple give a warranty for fixing the speaker?
完成的
They would have, but its long since expired and no extended warranty was offered.
完成的
添加一条评论
Anyone have a quote of how much it would cost to repair/replace?
这个答案有帮助吗?
得分 0
5条评论:
hi
buy a precision tool kit for $15 on ebay, ifixit are very good but more expensive for tools that wear down if your a pro, of course a pro gets the Switzerland versions.
the speakers are roughly $20
完成的
I have an early 2013 15" retina A1398. To get access on the speakers, you have to remove almost everything. Not worth it . I just got me a small JBL Bluetooth speakers. Great sound. In my area, it cost $100 -120 to replace the speakers.
完成的
apple wants you to buy a new machine, PERIOD, either buy a new one when it comes out or wait in line at a genius bar
完成的
Same problem- at Apple store now… $350
完成的
I'm in India. I paid around 5000 INR which equals to around 90$.
I suggest buying a Bluetooth speaker. My new speaker got blown again in 4 months. The warranty was only for 3.
完成的
添加一条评论
The IFixit guides are essential for performing any part replacements - but read and follow them with care - and read the user notes too.
After replacing my speakers, the left one is quiet - but I think that is a software thing - I’ve not fixed that yet …
这个答案有帮助吗?
得分 0
1条评论:
After a lot of fiddling, I think the reason one speaker is down on the other is that it is not an exact physical fit - not being an Apple replacement. If I loosen the back plate, the level equalises. I've upgraded the Mac now, so I've retightened the screws.\
完成的
添加一条评论
Will getting a Battery Replacement for the MacBook Pro gets you a New Speaker? Since a whole Top Part is being replaced.
这个答案有帮助吗?
得分 0
1条评论:
No, unless you need more than a battery replaced (e.g.- logic board, etc)
完成的
添加一条评论
添加你的答案
Athaariq Ardiansyah Ramadhani 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 109
总计 143,991
