跳转到主内容
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
Can you replace the rear fingerprint sensor/power button?
According to a few users
https://www.reddit.com/r/lgg5/comments/4...
Including myself, I have noticed that the G5's rear button is kind of wobbly and makes a clicking noise when you tap it. Can this be replaced or tightened up? Thank you for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
As you have stated and reinforced by the links you provided, it sounds as if a production run of these devices were not given a quality control final check. This does happen often on phones, and you can replace them but only within the 14 day period (if you got it from a carrier), but if you are beyond that time frame then you will need to contact LG about it.
However, it is possible to replace nearly everything on the G5, and this does include the buttons. Take a look at the photo provided in the iFixit teardown: https://d3nevzfk7ii3be.cloudfront.net/ig...
On the left, you can clearly see that they have removed the fingerprint scanner. This replacement is possible but I would not go through all of that work just due to a rattle. If the rattle became worse and the button started to slip or give inaccurate readings, then I would contact LG for a warranty claim. If you do the repair yourself or have a repair shop do the repair for you, it is possible to tighten it up if it is still a bit loose. Each person would have their own opinion on how to complete this task but it is possible. Yet again, I stress that if it is just a mild annoyance and does not impact the use of your phone, just deal with it--or contact the carrier or LG to get a new device--but I would not attempt the repair to fix something that is not broken.
这个答案有帮助吗?
得分 1
添加一条评论
I also have problems where I'm having to press the button alot harder to wake and close the phone, maybe something has gotten behind it. Time for a tare down video search.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 3,817
