Why is my machine losing its prime frequently
i have to prime my machine all the time even though i use it two or three times daily. its becoming harder tp prime . does anyone know the cause?
I'd suggest completely disassembling the unit, cleaning, and inspecting the tubing.
There could be a clog, but I think it's more likely that you've got a small leak somewhere that's causing you to lose pressure. Leaks are often right at the fittings.
这个答案有帮助吗?
Thanks Kyle
Could not find leaks. Could the pump suck in air???
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 138
