跳转到主内容
Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
How can I remove and replace the screen from the LCD cover?
The hinges for my display stop rotating so much. Eventually the plastic molds of the LCD cover (ferrules) broke off and the display is no longer attached to the hinges.
More info here:
http://forum.notebookreview.com/threads/...
So I want to by a LCD cover replacement and swap my current display into it. If I wanted to remove the display from my broken LCD cover how would I do that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Just figured it out while replacing my LCD cover.
When you have the screen separated from the body (and the hinge cover in the middle taken off as well), you need to hold the LCD cover (the back) steady, and slide the front with the screen downwards.
You should see a little gap form and stay at the top between the cover and the screen now.
After that, just apply a little upward pressure from the bottom in one of the sturdier spots between the screw holes, and the LCD should come up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jude Wynn 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 19
总计 1,897
