跳转到主内容
The Sony Xperia Z5 Android smartphone was released in October 2015. The Sony Xperia Z5 features 5.2 inches 1080 x 1920 pixels display and is equipped with a Qualcomm Snapdragon 810 processor alongside 3GB RAM and a 23 MP rear camera.
74 个问题 查看全部
Xperia Z5 LCD connector or screen?
My screen is not cracked, but half of it is dead or with discolored vertical lines. Will replacing the LCD screen fix this, or could the screen be fine but be an issue with something else? Are connectors included with LCDs when purchased?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
While I can make no promises, it should fix the issue. Was the phone dropped, or did this randomly occur?
The LCD and glass digitizer are fused together, so when you replace one you will be replacing both. The flex cables that attach the LCD and digitizer to the motherboard are included with every new screen. However, you will need to buy new adhesive for the screen.
This is a good example of the tape (however, this is a more expensive five pack). The LCD can be purchased here, as iFixit does not sell parts for this phone. If you follow the instructions on iFixit and take your time, your phone should turn out fine.
这个答案有帮助吗?
得分 0
1条评论:
Thanks. The phone was dropped and hit the floor parallel to it. I'll try to fix it myself.
完成的
添加一条评论
添加你的答案
Johnny 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 1,421
