跳转到主内容
加入维修社区 - 创建账户
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
iPod not taking charge
I have a 5th generation iPod, don't think its touch screen. It wouldn't take charge on cable, but on dock it shows a faint apple symbol. Does this mean it is charging? I called various places and said it may be the battery or charge port. I took it to get repaired and was told they could not change charge port as it was saudered to Motherbroad. Please help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Are you confident this is an iPod touch or no? I'm confused by the phrasing of your first sentence. Does the device work normally? Does it hold a charge?
完成的
Pretty sure he has an IPod touch 5th generation. As he said the store wouldn't repair the charger port as it's soldered to the board which is true.
It's not worth repairing imo caused too many issues myself trying to replace charger port.
Check the charger port for any blockage. If there is use a toothpick or something equivilant to clean it out. If the charger port does not go in fully this can be the issue.
完成的
添加一条评论
1个答案
Use your dock or get another cord it sounds like your cord has went bad and yes if you are getting anything on your screen it is charging sometimes it takes a bit if the battery is really dead
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nora Gaona 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 119
