How can I get the longest battery life out of my device?
My device seems to have been dying very frequently. I would like to get a much longer battery life out of my device. What can I do?
One thing is to be sure that your brightness is on the lowest setting.
You also should ensure that you lock (or shut off your screen) when you are not using your device.
Also make sure that all applications are closed when your device is not in use, it will preserve your battery.
这个答案有帮助吗?
If you are experiencing short battery life, consider replacing your battery with a new one. You can follow this guide to replace your battery: Insignia Flex 10.1 Battery Replacement
If replacing the battery does not resolve your problem, check out our troubleshooting page: Insignia Flex 10.1 Troubleshooting
这个答案有帮助吗?
You also may not to turn off the WI-FI when you are not using your device. When "on" your device even if closed continues to communicate with or search for a WI-FI signal. This function causes significant battery drain.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 190
