跳转到主内容
Announced in October of 2013. Identified by Model Number D610 and repair of this camera is similar to other Nikon D series camera of that year.
9 个问题 查看全部
问题已关闭
I can't get my camera to focus?
I have been taking a lot of photos lately but the past couple of days I have not been getting clear photos. I am using a tripod stand to shoot my pictures so stabilization is not the problem. Is there something that I am doing wrong or do you think it is a part failure?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The solution to your problem could be user error, a calibration issue, or like you said a part failure. If I were you, I would first try approaching the object you are photographing from a different angle or position. There might be too much going on in the background for the autofocus to find something to zone in on. If this doesn't work, you should then try calibrating your camera lens. Nikon calls this process "AF Fine tune" and you can purchase a tuning kit or do a DIY calibration.
Calibration kit
DIY Method
If that doesn't work, you may have to replace the focus motor. Refer to the troubleshooting page for the steps to replace this part.
WARNING: Replacing components on this camera is not an easy task and it requires a good amount of time and patience to do it correctly. There are many components and wire connections through out that will need to be re-soldered if you are not careful. Make sure you remove the battery and that the flash capacitor is discharged as it will hold charge even after the battery is removed and you will get shocked. If you do not have experience working with electrical components then you may be better off sending the camera to Nikon's service department to be repaired. It will cost a pretty penny, but you won't get shocked and your camera will not be damaged.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,102
