Are These Charging Contacts Burned on my Surface RT?
So this has happened, not quite sure what to do, I've ordered a new charger, but also want to know if I should be replacing the charger port? Is there someway to clean it or is it toast? I have found the instructions and parts here, I could do it, just wondering if I MUST..... The Surface RT is working but I don't want to use it until I get this sorted out, I use it daily, but have other computers, will be going through withdrawal .... All help appreciated, thanks in advance.
1条评论
New charger arrive, the second I plugged it in I smelled burning, so I know it's not the charger, next step is replace the port and then if that doesn't work, get a new tablet ...
由 shanonmc 完成的
