跳转到主内容
An Android 4.4 smartphone released in August 2014.
108 个问题 查看全部
What should I do when my phone says app have stopped working?
Good Morning. I have a Blu Studio 5.0 C. The problem that I have is that for almost all my apps now it is telling me for eg "Google app has stopped working, browser has stopped working". I am actually getting quite frustrated.
1. What could be the problem?
2. Is there a way that I can solve it?
I am in dire need to any sort of assistance at this moment please. Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Try a hard reset on your phone.
Be aware a hard reset will erase all your downloaded apps and user data. It will restore your phone to a factory default condition. It will be like when you first bought it.
Before you perform a hard reset:
1. Backup the phone using the phone's backup feature.
2. Ensure that the battery is charged.
3. Do not leave the charger connected when you perform a hard reset.
4. Remove the external SD Card (if applicable)
Here is a link that shows how to perform a hard reset on your phone. Try the second method first.
http://www.hardreset.info/devices/blu/bl...
Be patient it takes a little while to complete the reset.
Once the reset has been completed, test to see if the phone performs correctly. If it does, restore the phone using the backup that you made earlier. Use the phone's restore feature.
If the phone still performs correctly, the reset has corrected whatever was causing the problem.
If it once again has problems then it is one of the downloaded apps (not the pre-installed ones) that is causing the problem. You will then have to determine which one it is.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Krazii Khidd Kas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 158
