跳转到主内容
Updated Apple TV with second generation A5 processor / Released March 7, 2012
32 个问题 查看全部
Apple TV bricked, blank
Moved Apple TV to older tv, it did not have HDMI. I used HDMI to Component cable.
Did not get anything. Moved back to previous location hooked it up as it was, and the screen is blank. Restored on iTunes to original factory setting, connected again and.. The screen is blank. What to do now?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Now your apple tv work with convertor? And HDMI connect does not work?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Using a HDMI to component cable may have damaged the HDMI output circuitry of the Apple TV3 . You cannot convert a Digital video signal (HDMI) to an Analogue video signal (component) with just a cable connection. You need to use a converter such as in this example http://www.hdtvsupply.com/convert--hdmi-...
Here is one of many links regarding this problem.
http://www.hdtvsupply.com/hdmi-to-compon...
这个答案有帮助吗?
得分 1
1条评论:
Ok, may I somehow fix Apple TV After connecting wrong converter ? I have similar issue, and why it is bricked after upgrade not after connecting it to bad cable
完成的
添加一条评论
添加你的答案
milavic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,282
