跳转到主内容
加入维修社区 - 创建账户
A standard cordless compact DeWalt 18V drill with a high performance motor that delivers 380 watts. Equipped with easy to hold design that allows you to work in difficult spaces.
Why won't my drill operate?
When I push the trigger, my drill will not operate at all.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If your drill will not operate some things to check are if the batteries are low or may be dead. If the batteries are not holding charge you may need to purchase a replacement battery. Also your brushes attached to the motor may be old or have dirt built up which can be replaced by following a replacement guide. The motor, which is the main source of power, may be burnt out. It can be replaced by following videos or replacement guides or the connections to the motor could simply just be dirty. So I recommend wiping down the connections and seeing if that helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Hamel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 543
