跳转到主内容
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Sim card not recognised after screen replacement
I swapped out the screen and tested all ok, however when i put it all back together the sim card is not deteced. Strangley i took the back cover off and tried the card again, this time is is recognised, i've tested on a number of occassions and it look like whenever the back cover goes on the sim card cannot be detected, anyone have a clue what's going on here?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Check if the SIM Card slot cable is plugged in fully. If it isn't it may be moving off just enough for it to not give full contact to the connector to the logic board. This is a black cable located at the top right of the board. If it still doesn't work then the sim card slot or flex cable has most likely become damaged.
You can see where it is located in this video:
https://www.youtube.com/watch?v=y_MqDujJ...
这个答案有帮助吗?
得分 2
2条评论:
I have checked that already and it's fully in, the sim card does work but only without the back cover on it, it's very strange!
完成的
One more thing to try, follow the information given here:
http://www.techwalls.com/no-sim-card-err...
I'm assuming the usual short and/or long antenna cables are plugged into the logic board and the daughter board fine.
完成的
添加一条评论
添加你的答案
Flussig 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 6,600
