跳转到主内容
Improved second generation Google-branded tablet with a 7" screen.
98 个问题 查看全部
What parts should I replace after water damage?
Hi, I dropped my Nexus 7 2013 tablet into water. It is not responding and when I hold the power button, the light at the bottom flashes 5 times. I plan to fix this tablet.
There is not visible corrosion, and the screen, motherboard, daughterboard, plugs all look fine.
What parts should I replace?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Ensure that the battery remains disconnected from the systemboard until all parts have been very carefully and gently cleaned all over, with Isopropyl Alcohol 90%+ and a soft brush (you do not want to brush components off the board) and then allowed to completely dry.
Also check that the correct voltage is present at the battery terminals, by measuring the open circuit (or battery disconnected) voltage using a DMM (Digital Multi Meter-Voltmeter function).
When satisfied that you have done all you can, re-assemble the tablet and hopefully it may turn on successfully.
If it still doesn't start properly, at least you know that you can begin fault finding without having to worry about the possibility of errant circuit paths between components created by the water, (or more correctly elements, intended or not -think chlorine, fluoride, natural minerals etc, that are always present in all water, except distilled).
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Charles Li 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 343
