跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 个问题 查看全部
Keyboard replacement for intermittent keys
Is it possible to replace just the keyboard on this machine? It's done a lot of typing and the home keys have started acting intermittently. I'd rather not replace the whole top case if possible.
I've already popped the keys and cleaned out the underside of them but that had little effect.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Yes, you can replace the keyboard alone. You'll need to look on eBay to find one for your exact model. Follow the IFIXIT guide: MacBook Pro 15" Unibody Mid 2009 Upper Case Replacement and follow this YouTube: MacBook Unibody Keyboard Replacement.
这个答案有帮助吗?
得分 3
1条评论:
It turns out that you can, in fact, replace just the keyboard. I have yet to do so, but I was able to buy a replacement keyboard assembly off Amazon for about $30. You can get them cheaper if you don't want the backlighting.
It appears that there are about 50 tiny screws that holds the keyboard to the top case so that's going to take a while but it should work out great.
I'll report back here when I get it done.
完成的
添加一条评论
添加你的答案
David Jonas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 206
