跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 个问题 查看全部
问题已关闭
Retina Display replacement: whole assembly or just screen?
Hello, I need to replace a broken display on the Macbook Pro 15" Unibody Mid 2014 A1398 with Retina Display. iFixit has a guide only for the display assembly, not just the screen itself. Is this because only replacing the screen is undoable? Thank you! Charles
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
That is the general POV I have gathered across the web, despite there being a couple of Youtube videos showing how to do it on "similar" but not on a mid 2014 model that I am working with. Thanks to both of you for responding! Charles
完成的
添加一条评论
2个答案
已选择的解决方案
The screen cover glass on the Retina models is extremely thin, and is essentially impossible to perform with the amount of adhesive that Apple has smushed into the display assembly (why do you do this Apple?). While some people have been able to successfully disassemble the display assembly, it's extremely difficult, time consuming, and if you do it wrong, it becomes a really expensive paperweight (I'm exaggerating but you get the idea).
Sorry, but the entire display assembly has to be replaced at once. :(
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Just replace the whole assembly, it's too difficult to refurbish the display assembly with a new LCD
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 303
