跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
Is it possible to test a mic with a multimeter?
I need to test several mics for the iPhone 1st Generation. Sometimes they come damaged, and the only way to test them is soldering them to the System Connector. Is there any way to test a mic with a multimeter?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
If you want, you can cut the end off of a 3.5mm audio cable, and attatch the 2 wires to the mic, and plug that into the microphone/audio-in jack of a computer and see if you can hear anything.
这个答案有帮助吗?
得分 1
1条评论:
I will try and let you know...thank you!
完成的
添加一条评论
添加你的答案
Flavio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,358
