跳转到主内容
A compact food processor with an internal bowl scraper first manufactured in 2012.
Why is there a burning smell?
My Hamilton Beach Food Processor is giving off a burning smell when I turn it on, though everything is running fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
After the manufacturing process, the motor will often be left with residue. This is a temporary odor and should go away after repeated use. If the smell is reoccurring, stop using the device, as the wiring is more than likely faulty in the device. Also, as a side not, make you are only processing food, as "processing" anything else could lead to some odorous results as well.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Spencer Lynds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 30
总计 4,103
