跳转到主内容
The LG Optimus L90 is a smart phone from the third generation of the "Optimus L" series of phones manufactured by LG Electronics.
Why is my Touch Screen not working?
My touch screen does not register finger placements on the screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Screen protector Interference
Your screen protector may be the cause of the issue you are having. Remove your phone case and then proceed to use your touch screen. If your phone registers your finger placements, then your screen protector was the cause of your problem.
Screen is Locked
If your screen is stuck on one image and turns unresponsive, it is usually a software issue. Powering the phone on and off is a potential solution. If the phone’s display does not stay on or come on at all, then the lock button could be interfering. Try wiggling around the lock button or taking the back cover off the phone to see if there is anything interfering.
Screen Cracked
If the screen is physically cracked or damaged, then a replacement is usually the only fix here.
这个答案有帮助吗?
得分 1
1条评论:
i bought a tablet at wal mart
i bought a tablet from wal mart in 3/5/16 and i didnt know it was damage until my daughter came home from her trip on 3/27/16 that when we found it was damage and took it back to wal mart they wouldnt replacement cause the 15 day warrant was up how can i get replacement for it i even have the recipt to
完成的
添加一条评论
Wow! Your tips was certainly great! Thank you so much!
bold text
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 8,403
