跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s can only run about 5-10 min on full battery charge.
For the past few weeks my iPhone 5s (running iOS 9.3.1) has been acting really strange (and been really annoying). It will say 100% then 10 seconds later be at 90% and then just shut down. Then it shows the battery empty screen. I tried letting it charge over night but it didn't change a thing. I got around 10 minutes of use time out of it. Sometimes it will suddenly last 5 hours and I really don't understand what's happening here.
I do know my home button is broken but touch ID is still working. I had a guy look at it and he suspected it got shorted out, because there was no damage to any of the connectors. He couldn't find anything else. I hope someone can help me because it really makes my phone unusable.
EDIT:
Here are the pictures of the sides of my phone I hope they are good enough to see what I mean.
On here you can see that the screen isn't laying completely flat in the assembly.
As you can (hopefully) see the screen is pushed up a bit. On the battery side I can't push it down but on the side of the 'motherboard' I can. Don't think that is intended right?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I agree with Marty Morrow. See that if the battery is puffy and bloated.
if it is so, its the battery problem.
i think it can be fixed by changing the battery.
这个答案有帮助吗?
得分 2
添加一条评论
the obvious thing to look at is the battery. Did the guy who looked at the connectors check out the battery? It should read around 3.8V on a voltmeter. If it's higher than 5.0V, get a new one. also - visually inspect the battery - is it puffy and bloated? if so, time for a new one and be extremely careful removing the old one. the battery is glued down very tightly and requires heat to remove.
这个答案有帮助吗?
得分 1
2条评论:
The guy that looked at the connectors did also have some comments the battery. He didn't say anything special about it other than it being a bit thicker than normal, but didn't seem that worried about it (we were mainly looking for the cause of my broken home button and the battery was working okay at the time). When I looking at it now it does seem a bit thick especially considering it's pushing out my screen a bit. I will post some pictures of the sides of my phone above. I don't have any measuring devices at hand but will get to it as soon as possible and update further.
The only thing I don't understand is that it happened so sudden. Just from one day to the other it started acting like I described above. No slow decrease of usage time, but simply from about a days worth of usage to this. That's why I was thinking about my broken home button having contributed to this. Could it be that it is just charging really slow? or that it just charges sometimes and acts as if charging most of the time?
完成的
batteries can fail fast. (see articles about batteries starting on fire) so it's possible that this could just be a battery problem. have someone put a new battery in and test it to see if it fixes the problem. if it doesn't fix the problem, then you can decide what to do.
完成的
添加一条评论
添加你的答案
MisterMisterious 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 423
