跳转到主内容
The Nexus One (also known as the HTC Passion and Android Dev Phone 3) is a smartphone from Google (manufactured by HTC) that runs the Android operating system.
19 个问题 查看全部
I broke the camera what can I do?
I broke the lcd screen and the camera. I had no problem finding replacement part for the lcd screen but the camera lens is broken.
Update
Here is the picture:
The lens does not seem to be broken but the protective glass is.
Thanks for helping.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Can you post a picture of how it's broken?
完成的
And how long ago did you purchase it?
完成的
I won it with Google during the developper giveaway. So I cannot exchange it.
完成的
添加一条评论
2个答案
已选择的解决方案
Take out the damaged cover
and hand fashion a replacement cover from some thin clear Lexan. If you have no local source you can use some from small car models, or from some clear heavy gauge plastic container. Or KISS-from the inside stretch & glue some handi-wrap over the hole.
You want to keep the optic of the camera from getting scratched.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 2
添加一条评论
This is for the camera
it seems the camera can be replaced, but where u can get the replacement part of the camera...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Romain Griffiths 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 2,743
