跳转到主内容
加入维修社区 - 创建账户
Background, identification, specifications, manual, and disassembly guide for the Acer Aspire 5349. The Acer Aspire 5349 is a laptop of the Acer Aspire series that released in 2012.
Laptop won't boot up
My laptop powers on but takes forever to load. When I type in my password it says the password is incorrect and or the code works but the laptop continues to "load". Now when I turn it on I get just a blank/black screen...plz help me!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
If you're running Windows 8 or 10, you will have to trigger a refresh to solve the problem. I believe the answer key was F11. Top of F11 once per second the moment you turn your computer on, if that doesn't work after 15 seconds so, pull down your power button for six seconds until the computer turns off, and try again. If you fail this three times it will trigger a Windows 8 or Windows 10 automatic repair. From there, click on troubleshooting, and click refresh your PC - warning if you hit reset your PC you will lose everything, use the refresh feature specifically.
If you're running Windows 7, repeat this process but instead of tapping F11, tap if instead. Try logging in with that code or password again, And let's see if it does any better
这个答案有帮助吗?
得分 0
1条评论:
Thanks for replying to my question but my problem is still unresolved. I did everything u said but the screen is still black/blank. My screen said welcome for about 5 mins then just went black/blank. I don't know what else to do.
完成的
添加一条评论
acer aspire 5349 laptop wont turn on. when it charger is connected n if power button is pressed the LED light which is blue goes off. please help thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ebony 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 1,562
