跳转到主内容
The first-generation Ford Focus was manufactured in Europe from 1998-2004 and in North American from 1999 to 2007.
33 个问题 查看全部
2002 Ford Focus: Why does my battery light stay on
Battery light came on. So I swapped out the alternator. Put it all back together right. Battery light stays on had it all tested and it seems to be fine just wondering if anyone has had some similar issues
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Check your number 10 fuse in the underhood fusebox. It goes to the battery sensor. If that is fine, there has been an issue with positive battery harnesses on that model. You might check on that.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jeremy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,764
