跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Rear camera doesn't work even after replacement
Hi everyone
I have iPhone 5 that the rear camera doesn't work.
I have restore the phone to factory settings and replaced the rear camera and still no luck.
The camera is just black. Front camera working.
I disconnect the battery and connect it again.
Any more suggestions please help
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I have the same issue with an iPhone 5s.
完成的
Did you try to factory reset the phone with iTunes?
完成的
添加一条评论
3个答案
已选择的解决方案
For example it's not the first time that I see this component u13 fail. If you can measure the rear camera tension on the line before this component but not after it you can remove it and run a jumper to restore the tension that allows the rear camera to work. It could also be one of the many filters or capacitors that are on the rear camera connector lines, they are a lot. It's not easy to find the problem and it's also more difficult to fix it without a microscope and some experience in microsoldering.
这个答案有帮助吗?
得分 0
2条评论:
thank you very much for the support.
完成的
you're welcome
完成的
添加一条评论
Take it to Apple ask them for a complete fresh install of iOS not just a restore
这个答案有帮助吗?
得分 0
1条评论:
Any other suggestions different than taking it to Apple?
完成的
添加一条评论
There are several component on the board that could have failed so there is not the right communication between the logic board and the rear camera. It is a microsoldering work, without the right equipment and skills you can't do anything more than that, I'm sorry. You could try another camera but it almost impossible that the two you have now are both faulty.
这个答案有帮助吗?
得分 0
1条评论:
Hi James can you send me example of the components that may fail? Thank you
完成的
添加一条评论
添加你的答案
Mimi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 213
