跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for tablets made by Visual Land, Inc.
How to replace battery
how to replace battery on pad
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
You don't state the model number of your Visual Land tablet, so here is a link that shows how to open a Visual Land Connect 9. Hopefully it will be of some help.
https://www.youtube.com/watch?v=9PqV3keb...
Once open you should be able to access the battery and determine how to disconnect it. In the video it shows that the battery leads are soldered to the systemboard. So you may have to also unsolder them in your tablet. Take a picture of the battery wiring connections (red/black wires) before you disconnect them from the board to make it easier for when you have to connect the new battery wires to the systemboard.
You should also be able to get some information off the battery which should help you to source a replacement. It may not show a brand or even a part number but hopefully it may show the kind of information contained in the image below.
This is only an example and as far as I know it is not your battery.
It shows that it is a 3.7V 2500mAH battery with the dimensions of 3.5mm x 70mm x 95mm. So if you were to search online for this battery you would enter 3.7V 2500mAH 357095 into the browser search box and then select the result that suits you best.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
williamcordova1953 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 268
