跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Game Disk Stopped Working on my Nintendo 3DS
For awhile now, I have had a Nintendo 3DS (And I love it!) but just recently, I tried putting in a chewed up game, because it wasn't very bad. It didn't work, so I threw it away and when I tried playing another game, it didn't work, it didn't read the game. So, we took it in to a repair shop and they said that I had to go and return it to Nintendo in order to fix the problem. Unfortunately, it costs a FORTUNE! It costs about another Three-Hundred Dollars for a complete repair! I really like my 3DS and I don't want to lose it, does anyone know how to replace the 3DS Game Drive in the system?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Sounds like either the game you put into the game slot was really dirty or it messed up the pins on the slot. First things first, let's inspect your game slot to see if all the pins are there. What you'll need (if you don't have the tools available to open it up):
  • A toothpick
  • A flashlight/torch
1) Take the toothpick and insert it into the game slot and lift the shield in there. Once it's up, inspect the pins with your flashlight to ensure that there are no gaps and all pins are accounted for (I don't recall how many there should be but any missing ones will be apparent). If the pins appear to all be there then you'll want to get a cotton swab and rubbing alcohol and clean off those pins. Use the toothpick to keep the shield up and rub off the pins. After cleaning each pin, your cotton swab should be dirty. After that, you can test out the game slot to see if that's fixed the problem. If it hasn't, move on the next suggestion.
2) If it appears you're missing pins, you're gonna need a '00' phillips/crosshead screwdriver bit to open up the system to get at the game slot. When you have that, follow this guide to get at the game slot:
Nintendo 3DS Wi-Fi Board Replacement
From there, you'll see an opening in the game slot that you can use a fine point tweezer to pull any pins up that have been pushed down. Once the pins are all up, put the system back together and test your game slot again. If that hasn't helped or the pins are completely gone you're going to need your soldering set and a new game slot to replace it.
3) Replacing the game slot isn't the worst job in the world and there is a video by RetroGameTech that covers replacing a 3DS game slot. Watch that video and you should get a really good idea of how to replace the game slot. If you have to take this 3rd option, be very patient, take all the time you need and don't rush. Rushing may cause more damage than you first realise.
Good luck and I hope this info helps!
这个答案有帮助吗?
得分 1
添加一条评论
My game keeps saying no game inserted and it is. I tried everything that I have and keep saying the same thing no game inserted into slot
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
The Chosen One 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 72
总计 18,924
