跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
How to downgrade iPhone device
I want to ask about my iPhone 4S, current version is IOS9 ,and then how I can downgrade to IOS6 . It is due to when I upgrade IOS 9 my IPhone will become lag so I want to downgrade . Got someone got solution to help me ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
was it io6 before update , ? you would of needed to save the shsh blobs otherwise its highly unlikely its going to work
完成的
The only say you can downgrade is if you have saved signed SHSH blobs from before for that iOS version like seller1978 said.
完成的
I not backup SHSH ? How to fix
完成的
添加一条评论
1个答案
You need to wait for you current firmware to be jailbreakable and you can use tools to help trick the device into thinking ios6 is signed.
这个答案有帮助吗?
得分 0
4条评论:
But I don't want jailbreak
完成的
You have to first jailbreak the current firmware and then downgrade to ios6 which will erase your jailbreak and you will be left with stock ios6. Here is a link to odysseusOTA the tool used to achieve the downgrade. Keep in mind that you will need to be on a jailbreakable firmware. http://www.redmondpie.com/odysseusota-do...
完成的
Did you mean jailbreak first and then clean the jailbreak?
完成的
yes exactly. the jailbreak will be gone at the end.
完成的
添加一条评论
添加你的答案
JohnChong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 348
