跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone not detected and not chargin even after changing connector part
hello,
my iphone 5 was not detected and not charging anymore, I have changed the battery and it was perfectly working then, but still not charging.
Then i have decided to charge the whole block of audio jack and charging connector, i put all together again but still not detecting and not charging !
ANY SOLUTION OR CAUSE THAT YOU KNOW ABOUT THAT ?
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
have you tried a different usb cable , my iphone is very picky over charging cables , one of my cables will charge at the wall but cant use it in pc.
这个答案有帮助吗?
得分 0
添加一条评论
There are a few things that could be wrong, you broke a prong in the lightning connector or there is just something wrong with it and it needs to be replaced. It could also be the cable, test it out with and apple cable, not some knockoff. I myself had the same problem and the problem that i had was breaking one of the prongs in the lightning connector, if thats the case for you just buy one from the ifixit store.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marco Diversi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 81
