跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1526 个问题 查看全部
Recover data after water damage, does not boot up
iPhone 6 Plus -will not power on after water damage. Steps tried. Drying display connectors both from display and at logic board. connected to power via USB lightning charger and it will not power on. Is there a way to pull data of of this device with out using itunes and for free?
-Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
No, you will need to find a way to power up the device and connect it to iTunes or iCloud. It is not possible to decrypt the files without the key derived from the CPU UID and your passcode, so extracting the files from a dead board is not possible whatsoever.
And I predict there will be spammers promoting "data recovery" tools that are useless.
这个答案有帮助吗?
得分 2
添加一条评论
As Sunday mentioned in the comments below, your best bet is to send it to someone who does board level repair.
I would stop trying to connect it to power, as that will only make things worse.
There is definitely no free way of going about it. It's going to cost you money, so unless the data is worth a lot to you its probably not worth bothering.
If the data is valuable to you, you can find someone at http://boardrepair.info (including iPadRehab as Sunday mentioned) to mail the device to for data recovery.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Nate A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 262
