跳转到主内容
Device and repair information for the Lenovo Ideatab A1000 tablet.
17 个问题 查看全部
Why is my speakers are not working
There is no sound coming from speaker
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
Have you tried using earphones to see if there is sound when you use them and that it is not your speakers that are faulty?
If there is no sound when using earphones have you checked the audio settings in your tablet?
Go to Settings > Device > Audio Profiles and check the options there to see if your sound has been muted.
这个答案有帮助吗?
得分 3
1条评论:
My tablet has two speakers. The speaker on left side has stopped working. When I connect earphones or ear pods, their left side one doesn't work. Speaker or earphone of left side does t work. What may be reason?
完成的
添加一条评论
Hi @The Recreation Hub
What is the make and model number of your tablet?
If it is a Lenovo Ideatab A1000 then there appears to be no option to adjust the sound level between the left and right speaker only to increase/decrease the volume to both at the same time.
The model does have the option of a Dolby Digital equalizer adjustment in Settings but it seems this only works when the headphones are connected and doesn’t affect the speakers individually.
The reason why there may be no sound in the left speaker may be software related or more likely a hardware problem.
To eliminate software as the possible cause try the following:
i). Wipe the cache partition and check if this resolves the problem.
ii). If still no good, start the tablet in safe mode and check if it now works OK. If it does then a downloaded app is the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one and then test the tablet in normal mode between each uninstall to check if it works OK. When it does then the last downloaded app that was uninstalled was the cause. A downloaded app is one that you downloaded and installed in the tablet and didn’t come pre-installed with it.
iii). If still no good, try a factory restore. {see link in para. i) above}.
Be aware that a factory restore will erase all your data and downloaded apps. It will restore the tablet to its factory default condition. Backup the tablet to the cloud or a PC before attempting a factory restore. Also if the tablet has a Google account it may be prudent to know the Google account ID and password so that the tablet can be accessed after the factory restore. I’m not sure if the FRP lock (factory reset protection) applies to the Android version that is installed in the tablet but it won’t hurt to know it in case it does.
Once the backup has been completed, factory restore the tablet either using the link above or in the tablet’s Settings factory restore menu option.
Once the tablet has been reset to factory check if the left speaker now works.
If it still doesn’t work it is a hardware problem. Since if affects the left speaker regardless of the output connection i.e. speaker or headphones most likely it is on the systemboard perhaps in the audio IC circuitry. The tablet would need to be opened and tested as to where the problem is. Here’s a link to the hardware maintenance manual that may help to gain access to the systemboard.
If it now works OK, then using the backup created earlier, restore the tablet by using the restore feature found in the Settings menu area (same place as the factory restore). Once it has been restored to what it was, check that it still works OK. If so then the reset has fixed the problem
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
vanshith 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 25
总计 3,058
