跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
iPhone 5c Microphone doesn't work
A little while ago the microphone on my iPhone stopped working. There must be two mics, because phone calls work, but calls on speaker phone, Siri, etc don't work.
I'm going to be replacing my screen anyways, so I thought it might be a good opportunity to replace the microphone. But I can't find parts or a guide for such on here. Is it included in another set of parts or something? What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
That mic is located on the front facing camera cable. It's pretty easy to change that cable as part of the screen replacement.
这个答案有帮助吗?
得分 1
添加一条评论
Rich is correct. most likely needs replaced but the earpiece mesh can get also fairly blocked up which also includes a hole for that mic. if you remove the screen and that part then take a look at behind it, hold screen up to the light and you should see light pass through it. if not then scrape the mesh from the inside and outside with a fine pin etc to allow more sound to pass through.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Evan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 246
