跳转到主内容
Electrohome USB charging alarm clock radio with time projection. Identification model number: EAAC475.
6 个问题 查看全部
Time is ahead by 8 minutes
The time is off (ahead by 8 minutes) has gotten there gradually since purchased - it was fine when I first got it about 2 years ago. I am not able to figure out how to reset it. When there is a time change (Spring & Fall), it does adjust by an hour, but still wrong by same number of minutes.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
That is normal behavior for most clocks. The time accuracy is usually +- 1sec/month, or something like that. To set the time follow the instructions described in this photo.
这个答案有帮助吗?
得分 1
1条评论:
tried the buttons like you're supposed to.. managed to put the clock back one hour.. can't fix it :(
完成的
添加一条评论
FIXED!
Note: power off, remove 3V battery, power on, reset year/month/day/12hr(am/pm)/hour/minute, replace 3V battery
Note: The translated manual is unclear or at least NOT 100% correct, I did not find DST or time zone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Estelle 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 20
总计 2,300
