跳转到主内容
Budget tablet with 7.00-inch 1280x800 display powered by 1.3GHz processor alongside 1GB RAM and 5-megapixel rear camera.
wifi and location connecting automatically and wont switch off
Good day, its been 8 months since l bought my tablet and it has been working fine. Now from nowhere it switches on wifi and location and even if l try to turn it off it reconnects. How can l solve that problem without formatting the tablet.
Regards
Kalaz
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hi,
When your WiFi turns on unexpectedly, check your downloaded apps to see firstly if you 'know' them and then check to see which ones have permission to turn on both the WiFi and location functions. Then check your running apps and see if any of your downloaded apps are listed.
(I'm not sure if your tablet is set the same but the following is usual for Android OS, although it may be 'customized' by the manufacturer e.g. Apps may be called Applications or Applications manager etc.
Go to Menu > Settings > Apps > swipe left to Downloaded > tap each app to enter, then scroll down to view permissions.
Then go to Menu > Settings > Apps > swipe left to Running > Scroll down to view running apps.
If you find one or more of your 'downloaded' apps you will have to work out why it has started in the first place, if you hadn't started it already.
Also you may wish to download, install and run Malwarebytes for Mobiles to see if there is any malware that could be causing this.
Here is a link
https://play.google.com/store/apps/detai...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kalaz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 159
