Does my LCD need changing? Help ME!
Hello!
I have an IPhone 6 that I am trying to fix! It hasn't been used in a while as it is my partners sisters and she got a new one!
I have managed to get it to charge and turn on and I have restarted it by doing the 10 sec reset home and lock button!
BUT... I have now realised that the home button doesn't even work! The touch ID does but I cant get into the phone because his sister cant remember the passcode!
I would just DFU the phone but the screen is completely unresponsive. It doesn't work at all and it had about 10 light white lines down the right side of the screen.
So the question is should I replace the LCD and glass front? Will that make the screen work again?
And also if anyone knows what might be up with the home button! LET ME KNOW!
Thank you!!
You'll need to test it with a new screen and home button to see if it works.
由 Ben 完成的
The digitizer/LCD flex cable for my phone caused lines on the screen. I had to push the flex toward the lcd to get it to work. I just can't take it apart anymore or it will have problems again. As for the home button not working, could the home button flex have gotten bent too many times? Just the button function being disconnected.
由 Josiah 完成的
