跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
Low wifi + no sound during call?
Hi,
A year ago I dropped my iPhone 4 (my screen got totally broken and nothing showed on but when I put it in charger the phone vibrates) so now I bought another iPhone 4 with a broken motherboard and replaced the broken motherboard with mine. The phone started normally ;I backuped my data and restored it and after that I noticed that the wifi range is very low I have to be near the router to access to wifi and when I put sim card it detects it and shows me the signal and the carrier but when I call or get a phone call I can't hear the other side ,neither can he. I tried earphones with microphones but without success I noticed that if I dial a number in the keypad (http://i.i.cbsi.com/cnwk.1d/i/tim/2011/0...) during a call the other side hears the sound of the numbers and the 3G works without any problem I'm on IOS 7.1.2.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Check if you have the latest update installed.
Try to change date/time settings from Auto to Manual... restart the phone... and change back again. Also, check if you are logged in right Region. Sounds weird but this setting causes all kind of troubles all the time.
Hard reset (Power and Home button together till Apple sign appears)
这个答案有帮助吗?
得分 0
添加一条评论
I tried but without success :/
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ramzikerkeni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 66
