跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1526 个问题 查看全部
How to fix iTunes error 4013?
I've already replaced the battery and the Charging port with the sound port. I'm still getting this error and want to know what exacttly is broken. I really think it's the Logicboard because i've tried quite everything whithout luck. I hope anyone with the same error can help me out. Also if i try to restart the iphone it causes a respring loop. It's not Jailbroken and on iOS 9.2. When its powering on it goes off after a few seconds and starts again. If you know whats causing this let me know. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
Error 4013 is corrupt NAND chip in my experience. If under warranty--have it swapped, otherwise out if warranty replacement is your best bet
这个答案有帮助吗?
得分 7
1条评论:
change the c.c port first dosent wok change NAND :)
完成的
添加一条评论
Hi Max
Knowing that you already replace the battery, the charging port, having in mind you have updated iTunes and try few different original cables (with all USB ports on your PC/Laptop empty) there is one more think you can try:
This error could be caused by the lack of space for the update to install on your device. Try going to Settings>General> Usage – Make up some room in your memory.
Keep me posted
这个答案有帮助吗?
得分 1
2条评论:
I've already tried a few cables and also a virtual machine and a macintosh machine. For the space: I can't power the device on. It starts and power off after a couple of seconds.
完成的
You may need to change the battery again and make sure the battery is known good.
完成的
添加一条评论
I have the same problem , I saw some posts on You -Tube. if you replaced your screen, the home button is not recognising your phone. Apple has updated their software want you to use the original screen display.
这个答案有帮助吗?
得分 0
添加一条评论
i have same problem i fix Nand flash by third party tools like iPboxv2, you need hardware propositional to remove nand flash from pcb first
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max Mustermann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 10,770
