Dropped phone and S-Pen broke inside
My S Pen broke inside the phone. Is there a way to open up the phone and remove it to install another one?
My S -pen also broke. When I popped it out it went flying behind me. I found all the pieces, or so I thought. Going to a Verizon store was no help. Calling Verizon was no help. Finally I called Samsung and they told me to return it to them for replacement. Then I was in the Verizon store again and this time the rep. told me NOT to send it back to Samsung-that I'd get a refurbished one as replacement. Then the rep. smacked the phone down on his open palm and the (whole) pen dropped out. The force of the jolt when the phone hits the hand pops the pen out - at least partially. Just make sure the pen opening is extended out from the hand. Don't use a table or any other place that is hard.
The rep. suggested that I contact Samsung again and ask for a replacement stylus instead of replacement phone. The stylus had broken at the only "seam" on it and when it did, the spring was lost. Without the spring, the pop-out doesn't happen.
Hope that helps.
这个答案有帮助吗?
HA HA!! excellent, this worked like a charm! had to do it a few times, worked on the fourth try. Hold the phone vertically, and smack it against your open palm, insert hole first. It helps alright! big time.
Holy $@$* it worked lmfao
Thank you so much, it worked perfectly!
OMG!!!! You are a life saver!!!! I was about ready to send my phone to Samsung. I was freaking out. Thank you so much for this post!!!
Yep! worked for me too! I ordered a replacement stylus from a phone replacement part company I found online for $4.99! Just save the tips from the broken stylus before you trash it.
Yes you can but it is very tricky. The back of the note 5's are glass and that's the first thing that needs to be taken off in order to reach the inner part of the stylus. If you don't mind to break the glass, then I would say, go get you a blow dryer and some business cards and a razor and pry it off. After the back is off, you need to remove the screws to remove the plastic covering, then you will see your stylus holster and you will be able to easily remove the broken pieces of the stylus. here is a good disassemble video.
这个答案有帮助吗?
Mine did the same thing inside of my Note 5. I used a Kobalt 5/64 flathead screwdriver and inserted it into the pen slot. I poked a bit until I felt the opening where the tip was broken, pushed it into the slot and it connected with the broken pen. The activation sound pinged and the stub slid right out. About 30 seconds of work. Replaced with new pen and it worked great.
这个答案有帮助吗?
Thank You!! It work! YAAY!!!
Not sure how yours broke off, but in my case the 'tip' pulled off inside the phone. I tried the "smacking it vertically" method and that didn't work. I finally tried pushing a zip tie up into the slot; I felt some resistance and pushed just a bit more until I heard the 'latch' inside click, then pulled it back out and - voila!
这个答案有帮助吗?
The top piece of my stylus broke off and left the rest stuck up the channel in the phone. After reading the "vertical downwards thump" method, I tried that. It only took 3 thumps and I was astonished to see the rest of the pen pop out. It still works as well. I will consider the super glue method of attaching the top but will probably buy a replacement. I saw them for a reasonable price on EBay with free shipping to NZ. Thanks guys.
use a bobby pin! fits perfectly in the hole and gets stuck(? you can remove it after) then pull it out slowly ;)
这个答案有帮助吗?
worked like a charm!!
Totally worked!! I used jewelry tools to undo the bobby pin, then I made a curl at the end of the pin and it pulled everything out
Mine did the same thing so I just tried to put the other half of the s pen back in and when I went to take it out again the rest came out with after a couple of tries
这个答案有帮助吗?
Cut a cotton swab(like the one you use to clean your ear) and stick inside the holder it'll grab the stylus and then pull it out.
这个答案有帮助吗?
Got a question so a friend of mine gave me a galaxy note 4 (we dont have a plan with verison) and the pen broke would i still be able to get a new phone or stylist
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 16,613
1条评论
Use my thigh rather than the palm of the hand and it absolutely worked!
由 tmcmullins 完成的
