跳转到主内容
The AT&T Trimline 210M is a corded phone with a lighted keypad and 3 one touch memory buttons. Available in white and black.
Why is the keypad not lighting up?
The keypad on this phone does not function properly, the lights blink on and off. The actually keys stick in the down position.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Because there are only 2 LED's (one near the 5 key and one near the 7) that are dim since they are powered by the telephone circuit and don't have a wall transformer wired to the yellow/black pairs. Saying this phone has a "backlit keypad" is a false statement since all the keys can not be see in a dark room.
完成的
Further, when this phone is wall mounted, the handset falls out of the base making it totally worthless.
完成的
it will not fall out if you reverse the part that holds it. That is in the instructions.
完成的
添加一条评论
1个答案
There is most likely debris inside of the keypad. Open the phone and check the inside of the phone. If not, a part may need replacing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Brozik 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 507
