跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 个问题 查看全部
Water leaks from brew head when powered on
My Starbucks Barista drips water from the brew head when the machine is turned on and stops when the ready light turns green. I have stretched out the spring and replaced it but it still drips. What else could the problem be? Do I need to replace the group head gasket? Should I replace the tension spring?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
If it only drips a little and stops once the machine is up to temp this is nothing to worry about, as well as any dripping heating up to steam temp. If it drips excessively and/or doesn't stop then you could try replacing the silicone nipple on the end of the spring, or the spring itself, but the group head gasket plays no role in this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carlie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 495
