跳转到主内容
加入维修社区 - 创建账户
Huawei Ascend G510 Android smartphone. Announced 2013.
My phone is still at huawei startup logo
my phone is not start it is still hang on Huawei logo and after 10 min its atomatically power off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
6条评论
it is not helpful
完成的
I have the same problem too with my Huawei Ascend D1 Quad XL phone.
I tried to hard reset it but, it suddenly stops at “Huawei Ascend”. (It does not stop at its logo, actually)
I can’t turn it off. Even pressing the power key button does not work.
Respect post. Please help.
完成的
my huawei is blank only showing the logo on screen, cant seem to be able to switch it off.
完成的
My y9 2019 is hang with logo charger and never turn on please help..
完成的
my NCE-AL00 is hanging with huawei logo and not switch on
完成的
显示更多的1条评论
添加一条评论
5个答案
已选择的解决方案
Try following the steps specified here, it will tell you how to perform a factory reset via recovery and restore the system software on the phone:
http://www.hardreset.info/devices/huawei...
Make sure you charge your battery fully before doing any of these.
这个答案有帮助吗?
得分 10
添加一条评论
Initially facing the problem but after a lot of research finally found a proper solution.
Huawei stuck on boot screen, huawai hang on startup logo problem solution
Solved my problem bt this hope this will help you also.
To fix this problem you have to reboot your smartphone.
这个答案有帮助吗?
得分 1
添加一条评论
I perfome hardreset on my huwaei G525-U00 but it is still stuck on huwaei logo
这个答案有帮助吗?
得分 0
添加一条评论
If you can upgrade the Android system, it should solve the problem.
这个答案有帮助吗?
得分 0
添加一条评论
Hi I can't reboot also' so i'm stuck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
maeraj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 55,817
