跳转到主内容
Support for the CQ57 series of Compaq notebook computers.
38 个问题 查看全部
My CD/DVD drive just arbitrarily stopped working
This laptop is just a little over 3 years old - CD/DVD was working great then one day it just stopped playing CD/DVDs. When I go into the F drive, it says there is no CD/DVD ??
I've tried Microsoft 'FixIt' which did nothing and I also uninstalled/reinstalled the it , leaving the drivers then let the system find and reinstall.
Any ideas??
I've looked everywhere and am stumped :'(
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi,
I assume you mean that you cannot 'play' DVDs or CDs .
Does the tray power in and out? Is the DVD/CD disc rotating in the drive when inserted?
If so it may just be that the laser lens in the DVD/CD drive is dirty and needs to be cleaned.
Here is a link that shows how to do it. It is not for your exact model but it should be close enough to guide you.
https://www.youtube.com/watch?v=wayZD49a...
这个答案有帮助吗?
得分 4
10条评论:
Hey there thanks for answering.
Yes ...it starts to spin, then stops and won't play CD/DVDs.
The tray works fine.
I'll check out the link to clean it but someone told me I may need a new one installed. Cheaper to get a new laptop probably !
完成的
Hi, Cleaning it is definitely the cheapest option. Besides which you've got nothing to lose by doing it.
完成的
True! Thanks again for the link...getting ready to try it now.
完成的
Well that didn't work BOO! I'm thinking I can take the CD/DVD from my husband's laptop - it's the same as mine except one year older. Are they interchangeable? Looks easy enough to remove/reinstall from what I've seen.
完成的
Hi, By rights it should be alright if it is the same model. Here is a link to the service manual for your laptop. Scroll to p.42-43, it details how to remove the drive. If it still doesn't work after replacement, scroll to p.63 it shows that there is an ODD (optical disc drive -DVD drive) connector cable in your laptop. Check that it is connected properly at both ends http://www.hp.com/ctg/Manual/c03137362.p...
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Jo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 4,083
