跳转到主内容
加入维修社区 - 创建账户
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
Home button is stuck
I am trying to fix my ipod touch 5th generation and wondering how I fix a home button that is stuck down. What part do I need?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
thanks - a great help
完成的
添加一条评论
2个答案
最有帮助的答案
Enabling the Alternate Home Button
1. Open your iPhone’s Settings. If your Home button is not working, you can add a replacement Home button to your screen that appears in front of the apps you are running. This button will allow you to mimic the functionality of your non-working Home button.
> You can find the Settings app on your Home screen.
> If you can’t access the Home screen because your Home button is stuck, you can turn off the phone’s power and then turn it on again.
2.Tap General. In the General menu, find the Accessibility option. Once you are in the Accessibility section, scroll down and select AssistiveTouch. Toggle the slider to ON. A new button will appear on your screen.
> You can drag your alternate Home button to any position on the screen that you would like.
3.Press your alternate Home button. When you press the button, you will see four options appear. You can access Siri, your Favorites, your Device settings, or press Home to mimic the Home button and return to your Home screen.
> This method is available for iOS 5 and later.
这个答案有帮助吗?
得分 5
1条评论:
thanks = a great help
完成的
添加一条评论
How can I Fixed my home Button when it’s stuck?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
skyler hansen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 2,566
