跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Why can't I make or receive calls
My phone won't receive or make calls and I have no data. It only works on wifi but the calls just don't work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Need a bit more info, is the sim card detected?
完成的
cant` call out,can`t reseive,doesn`t pickup wifi
完成的
添加一条评论
2个答案
最有帮助的答案
. You're able to access this troubleshooting guide from another device or computer
2. You're in an Optus 2G / 3G / 4G Plus coverage area. You can confirm here.
3. You've successfully made calls at your present location before (unless roaming)
4. You're not using a Home Zone device
5. You've checked for a known problem with the Optus Network in your area. You can check here.
WHILST TESTING, PLEASE...
- Switch off Bluetooth and/or Wi-Fi on your device
- Monitor your device's status bar
- Use your device's native calling/phone application (Avoid using third party calling apps whilst testing)
这个答案有帮助吗?
得分 2
添加一条评论
  1. Yee I can text but onlybsms don't get or can't see ndvmms can't use data nd wen I try to call out it acts like it's gonna for a a cond then says call ended dose same to any one that trys to call me. It won't even ri g here .y number 6412752927 try to call it ull c its done this once before i some how fixed it then bout week ago I was on phone e talking. Nd it hung up nd started doing g it again. It's driven .e cra,y can u please help me figure out the problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 937
