跳转到主内容
Also known as the GS70 Stealth, this 17" gaming laptop was released in summer 2013 by Micro-Star International. Identified by the model number MS-1772.
Where can I order a replacement fan for the GPU?
My GPU fan is making extremely loud noises when it is running, (Basically, whenever my power cord is connected) and it sounds like the bearing is failing. I got one of the first models and I can't find a place to buy a replacement fan.
I live in the Netherlands.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi,
Have you tried Ebay.
Here is a link. If this is no good post your exact model number.
http://www.ebay.com/itm/New-for-MSI-GS70...
这个答案有帮助吗?
得分 3
3条评论:
Model number is: GS70 2OD-061NL or 9S7-177114-061
Those fans look quite a lot different from the once that are inside mine.
完成的
Hi, Can you see a 'part' or 'model' or any number on the fan or fan housing? If there is a number perhaps if you "Google" just the number you may have better luck.
完成的
I've found one. 90 Euro though if I include import costs. Guess it's better then buying a new Laptop. Thanks for your help
完成的
添加一条评论
One of the websites I am using to find graphic card fan replacements is:
https://www.gpufanreplacement.com
Just search on this website or ask them via live chat to get your exact fan.
这个答案有帮助吗?
得分 0
添加一条评论
original https://www.amazon.com/dp/B07CWHDLXM
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eternal Genesis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 5,169
