跳转到主内容
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
Why is the printer not turning on?
I bought this printer last year and never touched it or took it out of the box until now. The printer is brand new. I set up the internet connection without any problem. However, I started printing and all of a sudden, the printer turned off by itself. I tried turning it back on but would not turn on. I even tried changing plugs to see if the plug is the problem. What can I do to fix this printer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
3条评论
Did you ever find a way to make it turn on?
完成的
Hot %#*@ . It worked!! :0
完成的
When my school closed back in March I wrapped up my printer and kept it safe. Now it will not turn on at all and I have tried everything.
完成的
添加一条评论
2个答案
已选择的解决方案
1- Unplug AC cable
2- Hold Power button for 5 seconds (Keep holding it)
3- Plug AC while you hold Power button
4- Wait 10 more seconds and Power should come on
If that does not work after 2-3 tries, return it to the store or toss it out.
这个答案有帮助吗?
得分 13
20条评论:
holy smokes it worked!! thank you
完成的
Oh great one! You're the master.
完成的
Thanks it worked… GoodGood one
完成的
holy cow! The "toss it out" worked! Thanks
完成的
Thank you very much sir. my epson l380 finaly powered on. thanks a lot
完成的
显示更多的15条评论
添加一条评论
the issue is with the main board. there are 2 transistors that are broken down in your main board. had it replaced. second step is to manual clean your printhead by technicians and use it otherwise you end up with the same issue again and again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Khristille De Leon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 81
总计 39,819
