跳转到主内容
A compilation of guides for counter-top and handheld blender repair.
346 个问题 查看全部
stripped gear connected from the base of the blender to the pitcher
My Ninja blender 10100 watt model BL700 30 will not blend when I have something in it but will spin when it is empty it will not even blend ice cream I believe it is stripped in the base gear or whatever you call the gear looking thing in the bass that connects to the picher.. apart to get it off an epoxy it or something but I can't figure out how to get it off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Do not dispair. The stripped gears can be repaired by replacing the 3 small gears and just a small amount of enginuity. https://sites.google.com/site/dgeake51/h...
这个答案有帮助吗?
得分 2
2条评论:
How i can find thes pices tank you
完成的
Go to this site: https://sites.google.com/site/dgeake51/h.... Step by step instructions.
完成的
添加一条评论
Your blender has stripped planetary gears.
It's shot. Toast. Too hard to fix.
Why? 1. No easy parts suppliers. 2. Hard to disassemble when the gears are stripped because you can't separate the motor from the gears.
Ninja put in cheap (non-metal) plastic planetary gears in these units. They work ok for most things, but not for ice crushing drinks. While they put the motor mounts on rubber supports, and the drive connection to the base of the blender is rubber, these do not protect the gears from easily being overloaded with the large multi blade pitcher when it is full of cold (hard) ice.
They need to warn people who buy this for ice blended drinks to fill the blender only half full of ice. It's not strong enough to handle a lot of full-pitcher ice drinks.
Mine broke on the fifth pitcher.
They know about this problem, as you only need to search for it in Google. But why is it not fixed? Why is there no recall? Why does Costco carry it in view of their QC policy?
I don't know, but someone should sure get going on this problem I think.
这个答案有帮助吗?
得分 1
2条评论:
the plastic gear is cheap, bad design, they should have never made the gear out of plastic. throw it away and buy a new one
完成的
Where do you find the gears? I need to replace the planetary gear, but can't seem to find those kind of parts online.
完成的
添加一条评论
添加你的答案
allenmc503 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 60
总计 7,284
