跳转到主内容
The Seagate FreeAgent Go is a portable external drive by Seagate. It was released in May 2010.
11 个问题 查看全部
Error: The file or directory is corrupted and unreadable
Someone pulled the USB cable out of my computer while I was downloading files to the Seagate FreeAgent Go. P/N 9NN2A3-500, S/N 5LZ15WQV. Now I am getting this error message: Location is not available. J:\ is not accessible. The file or directory is corrupted and unreadable. I do not want to format and delete all data off the hard drive, is there another way I can fix this?
Sincerely,
Cyndee Horn
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
You should run checkdisk on the drive.
This is an utility that checks for, and repairs (or at least attempts to repair) file system errors.
There's no guarantee it will work in all cases, there's always a chance some data has been lost and cannot be recovered, but this is usually limited to the data that was being written at the moment the connection to the drive was lost.
Assuming you use Windows, here's the procedure:
http://knowledge.seagate.com/articles/en...
这个答案有帮助吗?
得分 0
添加一条评论
Hi Cynthia Garcia,
Please go this step to find what's the problem of you Hard Drive and then take a solution for that:
1- when you connect your hard drive, please listen to sounds of your hard drive.
2- if you dont hear any noise like a clicking, buzzing or unusual sound, take a breath :) .
3- Right click on my computer an click manage.
4- go to Disk management from left sidebar.
5- look at right section to find your Disk.
6- your drive statuss must be like any of this drives ( online , Healthy , NTFS & with a Drive letter )
7- please say me any reason or take a screen shot and show me what happen for your precious Hard Drive
I try to guide you to repair your hard drive
||| Good Luck |||
Homayoon Valizadeh
Hard Repair Expert from IRAN
这个答案有帮助吗?
得分 0
添加一条评论
Hi Homayoon
My Segate can not be found in my computer what should I do? I went all the steps youve mentioned on this page but I could not see my Segate. All I see as I connect my disk is the HDD lights!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cynthia Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,612
