跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 个问题 查看全部
What kind of graphics card can I upgrade to? Raedon r9 290?
I was looking at upgrading my graphics card to something a little better for gaming. I was looking at the Raedon R9 series preferably the 290 or 390. The problem is i have no idea how this works so I don't even know if these will physically fit in my computer. So can I upgrade to either of these (or another graphics card on par with these)?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Sadly, you cannot upgrade the graphics card in an iMac. There is not an actual graphics "card" so to say inside of an iMac. Instead, the GPU itself is soldered to the logic board. If you need more performance, you may want to consider selling your current iMac and putting that money towards purchasing a newer model.
这个答案有帮助吗?
得分 0
2条评论:
the iFixit website has a guide to replacing the graphics card. Is this just for replacing with the same exact thing or is it possible you're mistaken? (not trying to be rude, I honestly no next to nothing about this, I'm just trying to be sure before I give up)
完成的
I am so sorry, I was thinking about the newer iMacs. Yes, you can replace the graphics card in your machine but you can only replace it with one that is identical to the one that is already installed. You cannot upgrade it because newer cards have higher power requirements and run hotter.
完成的
添加一条评论
添加你的答案
Carter Hobbs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 177
